Fusion Manufacture
Bore: False positive collisions?
7 REPLIES 7
Message 1 of 8
FrodoLoggins
126 Views, 7 Replies
I'd assume so since I have "stop on collision" checked off but the tool never stops and the stock accuracy is set to the highest.
I'd assume this is due to me setting my bottom height 5 thou below the bottom of all holes but I don't always get collisions detected for all holes. Sometimes only a few holes lol.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
7 REPLIES 7
Message 2 of 8
brekmiller
in reply to: FrodoLoggins
That's a spurious shaft-collides-with-stock issue because the hole is deeper than the flutes -- the shaft is rubbing.
We have already fixed this issue.  Turn on "Preview Features" | "Stock Simulation Improvements".
Brek Miller
Software Engineer
Message 3 of 8
FrodoLoggins
in reply to: brekmiller
Thanks but doesn't look like I have Stock Simulation Improvements in the Preview Features section:
Also the tool is necked down. The shaft is a smaller diameter than the cutting diameter:
Also: Clicking the "escape" key did not exit me out of the dialogue for that toolpath, I had to click the dialogue's "Cancel" button. Happens every now and then.
Message 4 of 8
brekmiller
Since September, you need to sign up to the Insider program in order to get access to the preview features.
Any feature that you had turned on before September will still be available to you.  I see "Automated Arrange" in your image.  If you turn that off, you won't be able to turn it back on unless you become an Insider.
(Becoming an Insider doesn't cost anything.)
Brek Miller
Software Engineer
Message 5 of 8
FrodoLoggins
Just checked the install on my insider build. Not seeing it there either.
Message 6 of 8
FrodoLoggins
If I'm allowed to post a private youtube video of me opening my insider build and doing a search for it and send you a PM with the link let me know. Or I can email the file if it's small enough.
Message 7 of 8
seth.madore
It actually looks like Stock Sim Improvements is in "private preview"
Access to such features is granted on an individual basis and to a select user group. All I can say is "if you know you're good (for the toolpath and tool definition), just run it.
Seth Madore
Message 8 of 8
brekmiller
in reply to: seth.madore
D'oh.  You're right Seth.  Sorry about that.  The plan is for it to become a public preview in an upcoming release.
Brek Miller
Software Engineer
