Fusion Manufacture
Bore: Error: The top height must not be below the bottom height.
2 REPLIES 2
FrodoLoggins
122 Views, 2 Replies
Hi so I'm getting the below error but the tom height is above the bottom height:
Screenshot 2023-06-22 at 6.46.31 PM.pngScreenshot 2023-06-22 at 6.46.47 PM.png
And the holes are deeper than 5 thou:
The toolpath does in fact generate and simulate though:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
2 REPLIES 2
seth.madore
in reply to: FrodoLoggins
It looks like it's being caused by the "Select Same Diameter" option. More investigation is required..
Seth Madore
seth.madore
Further investigation is hinting at something else.
You have "Select Same Diameter, but you don't have "Select Same Hole Depth". Instead, you went with "Hole Top" for your top height. This appears to be considering the other thru holes on the perimeter, but failing because the heights defined don't allow for a toolpath. We can prove this out by selecting "Model Top" for our top height, in which case we now get this:
I don't think it's a bug, but more "questionable settings". You can achieve an error free toolpath by selecting "Select Same Z Top Height"
Seth Madore
