- Mute
- Permalink
- Report
If you use bore for a hole with 2 holes in line, first 10mm then 6 mm deeper, and select both faces in one bore action it starts with 6 mm and then 10mm, resulting in breaking the tool ! Temporary solution is to do 2 bore actions, one with 10mm hole and the next one with a 6 mm hole. But i think it should be possible in one go or at least block the faulty order.
Link copied
