Fusion Manufacture
Blending a circular groove without crashing.
4 REPLIES 4
ian1196
199 Views, 4 Replies
Learning Fusion and I want to machine a boss on a plate. I want to start at the boss as if the finished plate were very thin. I am using Contour2D. to mill several circular slots. When I do this, the tool path swings out to blend at the bottom of the slot. I want to avoid this. I would like to stay on the milling path and blend up to avoid tool stop mark. See drawing. How do I do this? Note my tool is designed for shallow cuts only.
4 REPLIES 4
a.laasW8M6T
in reply to: ian1196
If you go to the linking Tab and turn off the lead out, the tool will finish the cut and then retract straight up:
You also have the option of turning off "Same as Lead-in" and then you can modify the lead out paramters as you see fit.:
ian1196
If I am making an oring groove that is the same width as my tool, 2DContour will not spiral down , cover the bottom and spiral out at least some to avoid tool stop mark. Is that correct?
ian1196
Here is another thought. If I need to mill cut a shape out of 1/2" plate. I use 2DContour to cut the shape by spiraling to the bottom. I lift out like you said. no problem. The cut is ugly. I offset by 0.005"  and repeat but with a faster helix to get  a clean cut. How do I get out without making a tool mark? I use spiral in/out a lot if I have a two flute tool that has two small blemishes at the same depth of cut to avoid the blemish mark by the tool.
leo.castellon
Try using "finishing overlap"
LeoC
