Blend TPath works as expected with -.00014" stock to leave, doesn't when stock to leave is set to -.00015"
FrodoLoggins
FrodoLoggins
Selections:
-.00014" STL:Screen Shot 2020-09-18 at 10.33.44 AM.png
-.00015" STL:
Also unable to use stepovers smaller than .0078".
.00078" stepover:
.00077" stepover:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
kamil.malec94
Why do you not use a Parallel toolpath going on in the "X" direction?
Seems like a way easier solution and a nice clean toolpath. Might need to do an initial cut in the middle of the slot stepping down to remove large chunk of the material, Trace could do this job easily.
FrodoLoggins
Totally doable just noticed this bug
