Fusion Manufacture
Blend TPath generated 5 minutes ago but now: "Error: Too many curves contained in start curve."
4 REPLIES 4
FrodoLoggins
108 Views, 4 Replies
This blend toolpath milling just this used to generate:
Screenshot 2024-01-11 at 8.27.41 AM.pngLocated here:Screenshot 2024-01-11 at 8.28.07 AM.png
Then I added much more to the surfaces/curves (those found in the attached file "1.f3d"). But I got the below error:
So fine. 15 different blend toolpaths in this one setup aren't enough. I'll mill the chamfers one by one and have 30 blend toolpaths in this one setup. But after removing all surface/curve selections and starting over with JUST THE SAME EXACT SELECTIONS AND SETTINGS THAT WORKED THE FIRST TIME now I get the same error:
Attachment "2.f3d" contains only the 2 faces/4 curves found during the original toolpath that definitely generated perfectly fine and what I have now.
Guys. I REALLY need to get some work done.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
4 REPLIES 4
seth.madore
in reply to: FrodoLoggins
Can you share a version of the part from when multiple surfaces and multiple contours actually did work? As far as I can recall, it was always limited to single or multiple surfaces and two guide curves that contacted the selected faces.
Seth Madore
FrodoLoggins
in reply to: seth.madore
It's always been finicky when selecting more than one or two "contours" especially when they are near each other. But ya been doing that for 4 years.
seth.madore
Change it to the "old" method of stepover calculation of "On surface"
Seth Madore
seth.madore
I've logged an improvement ticket for "new blend" to work like "old blend"; CAM-50769
Seth Madore
