Fusion Manufacture
Blend toolpath not generating anymore
1 REPLY 1
FrodoLoggins
100 Views, 1 Reply
Definitely successfully generated a few weeks ago but today it won't and I noticed one of the drive curve selections is different. The bottom drive curve is shorter than what I originally selected. Right now it looks like this:
But it used to extend further like so:
Fusion just decided the edge was too long at some point so it decided to unselect half of it.
That edge is in fact made up of 2 edges. That component used to be 1 component that I split into 2 and then combined both back together due to Fusion's bugginess. And then further bugginess when I tried combining the two back together; combining one with the other would generate an error but combining the other with one combined successfully. Looks like we got a cornucopia of bugginess that's made its way over now to the blend toolpath. And now this forum must be cursed because I can't insert youtube videos:
That edge is in fact made up of 2 edges: https://youtu.be/qZwJwTOye9o
Now if I select the rest of the edge (what was enough to generate the toolpath a few weeks ago) it fails. Never changed the model or toolpath settings but it won't generate:
https://youtu.be/EJa21wHkai0
And the error I get:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
1 REPLY 1
Hi. I selected the missing piece of the bottom rail and changed the tolerance to .0004"
I remain hopeful that one day Blend will become more robust and user friendly.
