Fusion Manufacture
Blend: Error: Too many curves contained in start curve.
3 REPLIES 3
FrodoLoggins
115 Views, 3 Replies
So when using blend on these two chamfers:
I get the following error:
But by splitting them up individually using the same geometry selections and toolpath settings they both generate:Screenshot 2023-10-19 at 8.41.08 AM.png
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
Unfortunately, selecting multiple disjoint surface areas, and separate drive curves for them, is only supported for the "On Surface" stepover calculations.
If you change you stepover calculation, the calculation works for the selection you proposed. With stepover calculation "At Tip of Tool" you need to split the different chamfers into different operations.
Bjoern Johnsson
Principal Software Engineer
I'm gonna forget that. Do you know if there are any plans on making either stepover calc strategy compatible with things like these?
The end goal is to have both stepover calculations compatible for this. Unfortunately, I can't give you an estimate of when that will be.
Bjoern Johnsson
