Blend and Flow BUG!
HughesTooling
Blend and Flow BUG!
HughesTooling
Seems with this update you can only use Blend and Flow with a 5 axis machine configuration. See attached file.
Mark
Mark Hughes
Owner, Hughes Tooling
Replies (9)
Works for me
HughesTooling
You don't have a machine configuration selected. Select a 3 axis machine and it fails, thought I'd selected a machine in the file I uploaded.
Mark
Mark Hughes
Not disputing that, but it works if you don't select machine configuration.
To me, in Fusion, anything is a fair game if it works.
Is there a need to fix few things,.... yes, but until then ........ I use whatever works.
paolo.bastianelli
Hi @HughesTooling
I'll take a look at this or you. Have you found a machine configuration for which those toolpaths work for you?
Paolo
Paolo Bastianelli
Technical Consultant
paolo.bastianelli
Okay, I can confirm it's a bug and have reported it to the development team. Thanks a lot for posting about this!
I'll keep you guys posted after they assess the problem.
Paolo
Paolo Bastianelli
HughesTooling
@Anonymous
In this job I need to post to at least 6 different machines so setting a machine saves loads of time, especially when you end up posting to the wrong location or with the wrong post. This worked fine last week so the last update broke it. I already know it works without a machine configuration, just wanted to report the bug.
Mark
Mark Hughes
So, I have a general question regarding machine configuration. In everything I have done so far, I never use machine configuration in setup. When it was introduced, I understood that it is foundation for more complex tasks to come and few times I tried to use it, it turned out to be an obstacle for one reason or another.
At current point in time, what is the benefit of using machine configuration if what I need done works without it ?
And I wasn't playing smart a**, my domain is in lathe and mill-turn so I expend that into more then I need to get by, sometimes just fishing for answers or challenging myself.
@HughesTooling wrote:
@Anonymous
Mark
OK, I see where this is benefiting you, disregard my questions, you answered it while I was typing that post.
