Best strategy to select large amount of square holes for milling?
Bjanders
Bjanders
I need to mill a sheet with over 200 square holes (and later more than double that). What's the easiest way to create a toolpath for this without having to manually select each hole? The holes have a straight edge and a chamfer, so each hole needs two operations.
marcus.toepke
As first operation 2D-Pocket -> pocket detection
2. operation 2D Contour and link the selection from first operation with the 2D-Contour.
This way the 2D Contour is everytime the same as 2D Pocket
HughesTooling
Another option is to use a pattern and only select a single pocket. For this simple part maybe not the quickest solution but for parts where the toolpath calculation takes some time, patterns will calculate faster.
Mark Hughes
Owner, Hughes Tooling
Bjanders
Thank you @marcus.toepke and @HughesTooling! Your answers are very helpful and I learned something new once again.
