Best strategy to machine small area
PetePayne
PetePayne
I am still having trouble machining this small area in the pic.
What strategy would you choose?
3D pocket  clearing , 3D Adaptive or something else?
It is 5.5 mm wide with 1.5mm radius at the bottom.
4.5 mm is the bottom, from the top edge of the part.
Thanks for the help.
GeorgeRoberts
Will you have cleared out the hole first?
3D Pocket and/or 3D contour might be a good option here
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
PetePayne
George,
  Hello!
Yes I will have the hole drilled first.
GeorgeRoberts
Are you able to share the file? Perhaps I can add a couple of examples for you to try
Cheers
George Roberts
PetePayne
George,
    That sounds good!
Pete
GeorgeRoberts
Thanks for sharing the part! I have attached a program which shows how you might approach a finishing path with the 3D contour toolpath. For this, you will want to look at the boundary and patch that has been created
Cheers
George Roberts
PetePayne
George,
    I just had a chance to open it. So it looks like you changed the way I drew the one pocket???
Looked like it had a new plane for construction in it.
I got an error on the 2D pocket.
What are your thoughts.
