Best approach to machining multiples?
- Mute
- Permalink
- Report
I looked around a bit but didn't find an obvious result.
What's the best way to make several of a part? I've modeled the part in F360, done the CAM for it, and made one. But I'd like to step-and-repeat the operation a few times, as my stock is large enough to accommodate several. I've been doing it manually, by re-zeroing the machine to the right, and re-running the gcode. But I wonder if there's a better way. I don't really want to make multiple copies of the body in F360.
This is on a Tormach PCNC1100, if that helps with the answer. But I'm hoping I can do it in F360 CAM, by specifying the stock size and, and being able to simulate the results.
Thanks.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
Link copied
