Fusion Manufacture
Before starting program is running down into stock
2 REPLIES 2
geringandson
59 Views, 2 Replies
On the mill I have the stock size correct and clearance, retract, top and bottom height all correct, but when I set the origin to 0, 0, 0 and start the program it runs to X=0, Y=0, Z=-.12 then rapids to the XY starting point of the program (breaking the end mill) before going up to the retract height. How do I get it to rapid above the stock before starting the program?
Labels (1)
2 REPLIES 2
Running GRBL and/or G28's on your machine with no Z limit switch I presume?
Try this post if yes to the first question.
https://drive.google.com/file/d/1GrbGdGnClqoJmWhPXyTTiNor7o0sWzjz/view?usp=drive_link
Please click "Accept Solution" if what I wrote solved your issue!
It does have a z limit switch and I'm on g54
