Fusion Manufacture
Barfeed after barpull with sub
2 REPLIES 2
thierry924K4
119 Views, 2 Replies
Hi everyone
I got a piece and I am kinda stuck with it.
I do a barpull the do some more work and part off then i barfeed but I cannot figure out whzt the barfeef distance would be...
I start 25mm out of the chuck
Then 1mm cut to smooth the front
Then subspindle comes and moves 7mm over the part And grabs part
Then I move out 67mm (workpiece is 75mm (67 + 1mm of smoothing + 7mm of spindle grab)
Then some more lathe work and part of
Then i want to barfeed, i would say i should be 78.11mm (cuting tool is 3.11mm)
But it does not seem to work... i does not get back to 25mm...
2 REPLIES 2
seth.madore
in reply to: thierry924K4
okay, what does it go to? And what machine are you using, and how are you using Fusion to program your bar pull?
Seth Madore
thierry924K4
in reply to: seth.madore
First time went to 26mm and then i proceeded the job (cut of 2mm at once)
2e time it went to 50mm out of the spindle...
Haast20y
Spindlereturn - keep both spindles closed and offset to 67mm
Then another spindle return to zero
