Avoiding welded bolts in 2D Face milling
liz.radoy
Observer
liz.radoy
Observer
Observer
How can I 2D Face mill the top of the pink surface and avoid the bolts that are welded in? I have identified the bolts as part of the fixture, and it would not avoid these, I also choose all of the bolt holes and it still did not work.
programming2C78B
Why not program it as a 2D pocket?
Please click "Accept Solution" if what I wrote solved your issue!
engineguy
@liz.radoy
You can try leaving the bolts as part of your Model and then just selecting the Pink area and using  2D Pocket toolpath which should go around the Bolts treating them as Islands. See example image below for a guess at what you are asking for. If yes the see attached example file
engineguy
@liz.radoy
Just done a short video that may help you understand why that toolpath was chosen :slightly_smiling_face:
