Announcements
Autocad Icon under Setup
mmharris
mmharris
an icon that I have not seen before labeled Autodesk appeared under Setup in the attached f3d file
the png is a screenshot showing the icon
this is a test file trying to isolate a problem I'm having in a real part
what does the icon mean ?
jeff.pek
That's a machine, which has apparently been selected for the setup.
  Jeff
jeff.pek
It would be nice if it showed you more information when hovering over it; we should work on that.
You can also see evidence of the machine when editing the setup:
Jeff
mmharris
Thank you makes perfect sense once explained  ... so many other issues not sure what is a problem and what isn't
