Fusion Manufacture
Artillery sidewinder VS Manufacture
5 REPLIES 5
mac_ito
173 Views, 5 Replies
hello, I'm trying to get started with the manufacture module to generate gcode for my x1 printer but it seems difficult to get the desired results. I tried to set the origin to x:0 y:0 and x:150 y:150 but the result is the same, besides the purge line is not done so what appears in the simulation. In short, a bit lost. Does anyone have any good tips for getting fusion and x1 to work together?
5 REPLIES 5
mac_ito
in reply to: mac_ito
I didn't pay attention, maybe I should have posted this in the "Manufacture" forum? Maybe a moderator could move it?
Thx
seth.madore
Could you share your project here?
If you're a commercial/edu/startup, just right click on the file in the Data Panel and select "Share Link".
If you're a Personal User: File > Export > Save to local folder, return to thread and attach the file in your reply
What post processor and machine config are you using?
Seth Madore
mac_ito
in reply to: seth.madore
mac_ito
Capture d’écran 2023-03-04 à 22.55.35.pngCapture d’écran 2023-03-04 à 22.56.11.png
mac_ito
I don't know how or why exactly but the problem seems to be solved. On the other hand, what I noticed and which may explain the problem is that depending on the path taken, the modification of the machine parameters is not applied, is this normal behavior, I have a doubt, in any case for a first approach it leaves me perplexed
Capture d’écran 2023-03-06 à 09.03.04.pngCapture d’écran 2023-03-06 à 09.03.31.png
