Fusion Manufacture
ARRANGEMENT model update problem
2 REPLIES 2
daniele_spagli
123 Views, 2 Replies
I notice that if I do a setup of an arrangement or a piece in an arrangement and select it by the cursor instead by the name on the left, each time I make a little modify, the setup loose the connection to the body selected and so all the operations (machining) inside the setup.
I need to reselect again the body for the setup and the edges for the machining.
Why?
It didn't it before the update and the removed arrangement command from the  edit of the models for manufacture.
Any idea?
2 REPLIES 2
Can you capture this behavior in a screen recording?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
daniele_spagli_0-1693405375969.pngdaniele_spagli_1-1693405445069.pngdaniele_spagli_2-1693405492581.pngdaniele_spagli_3-1693405546171.png
