Arrange feature only works when a plane is selected. Does not work to select a sketch.
djlunty
djlunty
In the attached file I can only arrange the three components to a plane (xy plane).  If I try to arrange them on a sketch in the xy plane I get the error:  "Not all instances of part Frame:1 could be arranged in the selected area.  Try selecting fewer items or enlarging the area where they will be arranged"
The area is plenty big enough.  The problem is the part named "Frame".   The two "Bases" will arrange on the sketch if I select only them.   Don't know if it matters but the sketches were inserted into the model and are not native Fusion sketches.
I want to use sketches for the arrange feature so I can set up my CNC table size as a sketch.  What am I doing wrong?
Thank you for any solutions.
Doug
Replies (0)
