Fusion Manufacture
April 2023 - Since latest update "cylindrical face not in tool orientation" issues
16 REPLIES 16
Message 1 of 17
andy.concept303
729 Views, 16 Replies
Having a bit of a nightmare, I have a model and toolpaths that I have run previously with no problems, but seemingly since latest update this week, I'm now getting a load of issues with drilling and boring holes!
Note I didn't produce this model, I just added holes for fixturing, hence no design history except for the fixturing holes.  To try and fix this problem I've generated a new offset plane from the origin and used this for the sketch plane, still no joy.  Only work around I can come up with is to use 'select points', rather than cylindrical face, for hole selection, but this only work for drilling, I can't use it for the boring op.
Been using Fusion for years and never come across this!
Model attached below, thanks so much for any help!
16 REPLIES 16
Message 2 of 17
The holes are off angle from the plane that you've defined by a very small amount:
You can either select those holes to align your Z axis or turn on Tool Orientation to allow selection of them
Seth Madore
Message 3 of 17
Looking thru your timeline though, it appears that you created points on a sketch that was located on your Offset Plane, and then used those points to create hole features. It's logical that those features would be in line with your plane, but they're not. Further digging is required...
Seth Madore
Message 4 of 17
And you say that you've run this part before without issue? Or is this a new model and program that you're working on?
Seth Madore
Message 5 of 17
Thanks so much, totally understand what you're saying and yes I agree, but what I can't get my head round is what has changed.  I even found an old version of the model / tool paths which was used for machining previously, everything is fine, until I regen the tool paths, then they give this error.  Wonder if there's been a tightening up or rounding of a tolerances in latest release?  Very odd, but again thanks, I was pulling my hair out!
Message 6 of 17
Yeah I only created that offset plane to try and get round the issue, previously the sketch plane for the holes was generated on the model itself.
Message 7 of 17
I've opened up a dialog with someone from the Model side of things to see if something changed. Next step is to find someone in the "Drilling" section and run it by them
Seth Madore
Message 8 of 17
Many thanks Seth!
Message 9 of 17
 Could you open up that old version with valid toolpaths and export that out as an .f3d? Don't regenerate the toolpaths, just open and export and share here. I'd like to see the behavior on an older version of Fusion (I keep a laptop un-updated as long as possible for situations like this)
Seth Madore
Message 10 of 17
No problem, will do tonight when I get home.
Message 11 of 17
Here you go Seth, let me know what you find, thanks.
Message 12 of 17
Ah, but they aren't the same. In this part, you have your WCS aligned to your top face, not that offset plane. Toolpaths regenerate just fine:
Moreover, when I go to the file that you first shared and reset the WCS to the top face, all the toolpaths now work. There's something about that plane.....
Seth Madore
Message 13 of 17
Well, this is all very strange....
Yes, I used that offset plane as my initial workaround, as the top face of the model was what seemed to be giving me all the issues.
I have also just swapped back to this model top face for the Z ref and everything regens OK!  Go figure....
Sorry to have wasted your time Seth, really appreciate your help.
Message 14 of 17
Actually, I don't think you wasted my time, as the plane should have worked. Even if it hadn't, the WCS set to the plane along with Tool Orientation should have certainly worked. We're going to continue looking at the issue and determine the root cause and (hopefully, eventually) fix it
Seth Madore
Message 15 of 17
arcapaldo
in reply to: seth.madore
after today's update (05/06/2023) i solved the issue
Message 16 of 17
seth.madore
in reply to: arcapaldo
Yep, this issue should now be fixed with the latest update. Do let us know if you encounter this bug again!
Seth Madore
Message 17 of 17
franktpw
I'm having a similar issue using HSMWorks Ultimate 2024 within Solidworks. Had never seen this issue before, but upgraded from HSMWorks 2023 to HSMWorks 2024 today and I can't pick the cylindrical holes and get the message:
"cylindrical surface can be drilled only with opposite tool orientation"
