Fusion Manufacture
April 2023 Post Processor and Machine Simulation What' New
0 REPLIES 0
Message 1 of 1
andrea.amilo
1104 Views, 0 Replies
Post Processor and Machine Simulation What’s New
Looking for the latest post processors and machines updates? Look no further!
We are continually working hard to bring you updates and improvements to the many open-source Post Processors and Machines we offer for free, but those updates often get lost in the shuffle of other enhancements or big feature releases. This post aims to update you on newly added or improved post processors and machines, so you can stay up to date on what you use today or look for news so you can get the most out of Fusion 360.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. Improved Processors
  2. New Machines
  3. Improved Machines
  4. Tools and Tool Holders
  5. Post Processor Engine
1. Improved Post Processors
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Generic Post Processors
milling.png- Improved modal command output in several post processors
- Multiple internal optimizations in generic post processors.
Milling Post Processors
ACU-RITE MILLPWR2
Updated acurite millpwr2 post to use shared content across post processors.
anilam iso_thumbnail.pngAnilam ISO
Updated anilam iso post to use shared content across post processors.
APSX Spider
Updated apsx spider post to use shared content across post processors
AXYZ
Updated AXYZ post to use shared content across post processors.
Carbide
Updated Carbide post to use shared content across post processors.
Datron C5, Datron MCR
Fixed location of Manual NC command output in the Datron MCR post processors.
Kimla
Updated Kimla post to use shared content across post processors.
Mach2Mill, Mach3Mill, Mach4Mill
Updated MachMill post to use shared content across post processors.
Matsuura
Updated Matsuura post to use shared content across post processors.
Mekanika CNC Router
Updated the Mekanika post processor to the latest version of the LinuxCNC post.
Siemens 840D Inspection
- Add live deviation calculations to the Siemens 840D Inspect surface post processor.
- Make Extended Cycles default and fix some drilling cycles in the Siemens post processors.
Syntec
Updated Syntec post to use shared content across post processors.
Techno CNC router
Removed the G92 output from the Series LC model of the Techno CNC Router post processor.
Tormach PathPilot
- Added support for rigid tapping to the Tormach milling post processor.
- Added a property to control the tapping retract spindle speed to the Tormach milling post processor.
- Fixed the placement of Manual NC commands in the Tormach milling post processor.
- Increased the accuracy of the feed rates in the Tormach milling postprocessor.
Turning Post Processors
Fixed "saveShowSequenceNumbers" definition in all turning post processors.
gskcnc turning_thumbnail.pngGSK CNC Turning
Removed output of G17 from the GSK CNC turning post processor.
Mazak Turning
Added tapping with chip breaking cycle to the Mazak turning post processor.
Tormach 8L Turning, Tormach 15L Turning
- Added the ability to select multiple tools in a single turret pocket in the Tormach 15L turning post processor.
- Added tapping with chip breaking support to the Tormach turning post processors.
- Added a property to control the tapping retract spindle speed to the Tormach turning post processors.
Mill-Turn Post Processors
- Added the 'Only on tool change' option to the 'Use sequence numbers' property in mill-turn post processors.
- Fixed "saveShowSequenceNumbers" definition in all mill-turn post processors.
Doosan Mill/Turn
- Optimized the Polar Coordinate mode logic in the Doosan Mill/Turn post processor.
- Changed the multi-axis feedrates to use combination FPM/DPM feedrates in the Doosan Mill/Turn post processor.
Haas CL-1, Haas DS-30Y, Haas DS-30SSY, Haas ST-10, Haas ST-15, Haas ST-20, Haas ST-25, Haas ST-28, Haas ST-30, Haas ST-35, Haas ST-40, Haas ST-45, Haas ST-55, Haas ST-10L, Haas ST-15L, Haas ST-20L, Haas ST-25L, Haas ST-28L, Haas ST-30L, Haas ST-35L, Haas ST-40L, Haas ST-45L, Haas ST-10Y, Haas ST-15Y, Haas ST-20Y, Haas ST-25Y, Haas ST-28Y, Haas ST-30Y, Haas ST-35Y, Haas ST-10LY, Haas ST-15LY, Haas ST-20LY, Haas ST-25LY, Haas ST-28LY, Haas ST-30LY, Haas ST-35LY, Haas ST-20SS, Haas ST-20SSY, Haas ST-30SS, Haas ST-30SSY, Haas Turning
Ensure feedrate is output with expanded cycles in the HAAS lathe post processors.
Additive Post Processors
- Changed the comments handling in the fff post processors.
- Moved the M83 command after the G90 command in the FFF post processors.
2. New Machines
Machine Library
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
You will have available configuration files for some of the leading machine manufacturers:
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
Updated Haas GM2-5AX machine file to use the correct post processor.
The Tool Library lets you manage tools for Milling, Turning, Cutting (waterjet, laser & plasma), Touch Probes and Holders. The Tool Library lets you manage libraries of predefined tools and project documents.
Blum Touch Probe
Blum-Novotest a global leader in technology and innovation in measuring and testing technology. A reliable partner to the global machine tool, automotive and aerospace industries.
Our development team is always working to update and fix the Autodesk CAM Post Processor engine. These modifications are not related to a specific postprocessor (as described above) but affect the entire library or at least the post processors using that specific class. The current post processor kernel is 4.5946.
API.pngExtra lines are no longer added to the output NC file when setWriteInvocations is enabled.
API.pngUse an even degree increment when calculating rotations that will keep the machine within the limits of the linear axes in the section.getABCByPreference function.
API.pngOptimize polar interpolation when crossing the center of the rotary axis.
API.pngProcessing process works fine when a post processor has a property defined with a scope setting of "operation" and a cascading post is used.
API.pngThe rotary axes will no longer go outside of their defined limits when the toolpath is linearized around the singularity.
API.pngUpdate post engine to include new strategy 'inspectSurfaceGeometry'
You can find here all the information regarding the Autodesk CAM Post Processor engine.
Click here to see the previous What’s New release
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
0 REPLIES 0
