Any toolpath I try doesn't completely clear the top left pocket
reinketate
reinketate
I've tried 2d pocket, adaptive clearing, flat, and horizontal and none of them have worked. this also happened to some of the letters in a different setup.
seth.madore
Well, that's unexpected..
Could you share the file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
reinketate
Here it is
seth.madore
I just wanted to offer a bit of gentle correction, first off...
Your modeling workflow would benefit from you introducing more stable methods of locating your bodies (actually, these should be Components, not Bodies). The Move command is not something one should make liberal use of, but rather, Joints are your ally.
Okay, off my soapbox now!
The issue at hand is in your Setup. You've selected the CAM Component root directory, which includes EVERYTHING, including any Body/Component that may not have been visible at the moment. So, when we turn on all the Bodies (again, these should be components), we discover this:
 There's an extra Nebraska hanging out in your first part and that's preventing any "Model Aware" toolpath from going there.
Seth Madore
reinketate
Thank you for the correction. I'm very new to this and thankful you helped, I'll take not of this
seth.madore
Totally understand, we all certainly start somewhere 🙂
Seth Madore
iuliancalin22
i had the same issue with my projects, but after some feedback i improved my project alot.
take a look on my post and see how it helped me
it might be a bit frustrating at first but it will help very much
https://forums.autodesk.com/t5/fusion-360-design-validate/i-designed-a-small-cnc-need-feedback/td-p/...
