Fusion Manufacture
Any ideas on the best way to achieve this ramp?
3 REPLIES 3
Ryan_Fab
99 Views, 3 Replies
Im hoping im able to pick the highlighted contour and let the tool cut simultaneously in xy&Z. I just cant manage it
Any help greatly appreciated. File is attached
3 REPLIES 3
seth.madore
in reply to: Ryan_Fab
Blend should get you something decent. However, without doing some funky setups, you're not going to be able to achieve an exact replica of your model. We have tool nose radii to consider..
Seth Madore
Ryan_Fab
Hi Seth, thanks for taking a look. Im hoping to do it fairly quick. Im not too fussed about recreating exactly whats modelled, Im trying to generate a channel for some wires, so they dont snag on any edges. I havent modelled it but the wires come from a hole at the bottom of the internal radiused corner
Is there a way where I could drive the center of a ball nose across along the sketched path above? As im typing ive just thought of trace, ill go and give that a look
cheers
seth.madore
I'd steer you away from Trace, it will likely gouge. Project would be my first choice
Seth Madore
