Fusion Manufacture
alter c axis limit of degrees of rotation
4 REPLIES 4
c.teasdale.contact
236 Views, 4 Replies
Hi there
I'm trying to 4 axis machine on lathe with fixed c axis and live tooling in x
Posts with c values starting and 0 then when it gets to 359.99 (for examples) the next c value is 1' (rather than 361')
My machine rotates the long way back to 1 rather than the short travel to 361 (1) when posted this way
I am aware some machines have parameters you can change to ignore this but unfortunately I can't find a way to make mine treat the c axis as linear
machine is Hitachi Seiki Hicell L111/A
Machine has stroke limit of C9999.999 so hoping to programme c rotation up to this value, split programme and continue
Also tried parameter 1600 #4 on machine
Is there somewhere in processor edit that I can up the C value limit?
4 REPLIES 4
Hi @c.teasdale.contact
What is the post you are using?
you can find the line in the post like this where it sets the range and set the cyclic to false this will solve the issue
Attach the post here if you could not find this
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[0, 9999], preference:1, tcp:false});
Boopathi Sivakumar
Senior Technology Consultant
Hello; many thanks for the reply, you are exactly right - I edited one of
the posts in the library this morning
For anyone else trying to edit this sort of thing , text edit and command f
to find the section I was looking for
It's easy when you know how!
Hi, I've since tried this for C axis alteration
if (true) {
var bAxisMain = createAxis({coordinate:1, table:false, axis:[0, -1, 0], range:[-0.001, 90.001], preference:0});
var cAxisMain = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:false, preference:0}); // C axis is modal between primary and secondary spindle
var bAxisSub = createAxis({coordinate:1, table:false, axis:[0, -1, 0], range:[-0.001, 180.001], preference:0});
var cAxisSub = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:false, preference:0}); // C axis is modal between primary and secondary spindle
A problem I have is my machine only reads C values up to +/- 9999.999
Programme goes up to 30000.
I tried:
if (true) {
var cAxisMain = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:false, range:[-2800., 2800.], preference:0}); // C axis is modal between primary and secondary spindle
var cAxisSub = createAxis({coordinate:2, table:true, axis:[0, 0, 1], cyclic:false, range:[-2800., 2800.], preference:0}); // C axis is modal between primary and secondary spindle
I also have to split the programme up as it is too large so have to run in 30 separate programmes - this means I need to move out at around c2800 for first programme and rejoin in job with continued programme
I need to be able to set C output limits as tried above but I'm getting this error:
Error: REWIND: Rewind of machine is required for simultaneous multi-axis toolpath and has been disabled.
Stop time: Mon Feb 20 16:57:30 2023
Post processing failed.
Am I trying to input a range in the wrong place? Please help!
