Fusion Manufacture
All my cloud tool libraries are missing
7 REPLIES 7
Message 1 of 8
simspacetn
319 Views, 7 Replies
I just opened Fusion and all my cloud tool libraries are gone.
They were there on Team Hub yesterday.
I'm trying to complete a project and I can't without my tool library.
Anyone have any ideas what may be happening?
When I look under CAMTools, the .json files are there.
Chris
7 REPLIES 7
Message 2 of 8
a.laasW8M6T
in reply to: simspacetn
Do you use the cloud for other libraries? posts, machines, templates?
Are they there too?
I had a similar issue the other day but all my stuff was in the trash.
Message 3 of 8
simspacetn
in reply to: a.laasW8M6T
@a.laasW8M6T Machines and posts cloud files are there too (see image below).
Also, I downloaded all the tool libray files locally. All the JSON data is there.
And the assets trash folder is empty. And the trash folder under CAMTools is empty too.
I signed out and signed back into Fusion/Autodesk. I rebooted. Still no luck.
Message 4 of 8
a.laasW8M6T
Ok that sounds like a different problem to what I had.
This may be a work around, You have already downloaded all the files to your PC, Now import them into the Library again
see if that works
Message 5 of 8
simspacetn
Okay, I'll give that a shot and report back. Thanks!
Message 6 of 8
simspacetn
Here's how I solved the problem thanks to an Autodesk support team member named Jeff Pek...
  1. Shut down Fusion completely.
  2. On Mac OS I opened the folder:
    ~/Library/Application Support/Autodesk/Autodesk Fusion 360/BRV4J2FW2NMJ/W.login
    º The `BRV4J2FW2NMJ` folder may have a different name on your mac.
    º ~ is your home directory, usually /Users/<username>.
    º In Finder you may need to press `cmd-shift-.` to reveal hidden files to see the `W.login` folder.
    º On Windows navigate (Explorer) to the folder %localappdata%\autodesk\autodesk fusion 360\<userid>\W.Login.
  3. Rename (don't delete) the "M" folder to anything (I renamed it to `zzz`).
  4. Restart Fusion and check your cloud tool libraries, they should be there now.
  5. If that worked, you can now delete the renamed "M" folder (which in my case is now `zzz`), but keep the new "M" folder. Do not delete that one.
Message 7 of 8
jeff.pek
FWIW, the keeping (renaming, not deleting) of the M folder isn't necessarily needed, but it preserves some backup data, in case the steps called out don't resolve the issue.
In this case, since things appear to be synched up again, it's safe to delete.
Jeff
Message 8 of 8
qualityBYUK6
This ha just happened to me and renaming this folder did nothing for me.
I also seem to be missing the cloud tool library all together.
Anyone know how I can get these back in my tool library in manufacturing?
Edit: Got it sorted. For some reason my fusion blipped back to a fresh install layout. Everything was back to defaults.
I had to goto into preferences and enable cloud libraries under manufacturing.
