Fusion Manufacture
Advice on best machining strategy for large radius
2 REPLIES 2
ashes.man
142 Views, 2 Replies
I am a little stuck trying to work out the best tool to use and machining strategy for the radius/fillet in the picture below.  I am after advice on how to get the best surface finish.  I have a few options on ball nose tools from around 6 to 20mm diameter.
Part is 6061 aluminum on a small 3 axis machine.
I got as far as roughing it out:
File attached if it helps.  Mostly I am just after advice on tool selection, feeds, speeds, stepovers etc.  And most appropriate tool path option.
I tried a few of the 3D tool paths but not sure which one would give the best result in practice.
2 REPLIES 2
seth.madore
in reply to: ashes.man
Here's a Flow(Preview) option:
And here's a Blend option:
These are quick examples, it's likely that better toolpaths can be obtained.
As for speeds and feeds, I tend to run a .375" ball endmill to the max rpm of my Mori (12k) and a feedrate of about .001" chip per tooth.
Seth Madore
ashes.man
in reply to: seth.madore
Thanks for the suggestions. I will have a play with those tool path options. My Mazak is flat out at 6000 RPM so have to choose a stepover that doesn't take all week to run but leaves a good finish. In the past I havent had much luck with this sort of profiling. I think it is due to tool rubbing or maybe just need a sharper tool!
