Additive - Selecting single nozzle machine keeps using Nozzle 2 settings
Eric_Schubert
Eric_Schubert
I have my printers set up in the cloud machine library to have default print settings.  When I select my printer at the beginning of a new setup, Fusion 360 has started picking the nozzle settings for Nozzle 2, not Nozzle 1.  I only have one nozzle.  Fusion 360 shouldn't even pay attention to Nozzle 2, or probably even show me Nozzle 2, as the machine settings state I only have one nozzle.  In the past, I've sometimes never even seen Nozzle 2 show up when editing print settings, which is great.  I can't use them anyway.
I can probably get around this by setting the Nozzle 1 and Nozzle 2 settings to be identical in the print settings library.  But, I don't want to have to keep changing both sets of settings every time I make a small adjustment.  This is irritating and should be unnecessary.
In the attached images, you can see the print profile I have selected and the two sets of settings for Nozzle 1 and Nozzle 2.  In the g-code, clearly it is using settings for Nozzle 2.
Sometimes I can get it to reset by picking the print settings again, but lately it's been stubborn and not correcting the issue.  I've tried switching to a totally different print setting (such as PLA) then switching back (this one is PETG).  That isn't helping anymore, though.
I've restarted Fusion 360, reselected my print settings, it's not sticking.
Replies (0)
