Fusion Manufacture
Adding Tabs in 2D Profile (LASER CUTTING) to curved feature creates Warning-passes discarded
8 REPLIES 8
Message 1 of 9
MJP63
212 Views, 8 Replies
Whenever I manually add tabs in sheet metal fabrication nests to a curved feature (hole, oval etc) I get:
Warning: One or more passes were discarded due to linking constraints.
Am I missing something or is there a good workaround?
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: MJP63
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 3 of 9
MJP63
in reply to: seth.madore
Thanks Seth!
The design was sent to me from a customer.  We do the sheet metal work for them and I do the nesting and Gcode.
We have not had this issue with other designs; but none have had the ovals until now.
I noticed that if I break a single part out from the design and nest just that part with the same parameters, I have no problems.  But we need all these parts nested for utilization.
I was using manual tabs as I only need them on the ovals.  It also gives me the warning if I add one to the one larger round hole.  I have tried multiple locations on the contours to no avail.  We do not use lead ins or outs.
Any thoughts would be appreciated.
Mike
Message 4 of 9
seth.madore
in reply to: MJP63
If you could email me a link to the file, I'd be happy to take a look at it. Right click on the file in the Data Panel and select "Share Link". Make sure that it's set to "Allow items to be Downloaded" and email me the link:
seth DOT madore AT autodesk DOT com
Example:
Seth Madore
Message 5 of 9
MJP63
done...forgot to attach to my last reply
Message 6 of 9
seth.madore
in reply to: MJP63
Yep, I can confirm that this is an issue. There is a workaround, but it does require setting your Pierce Clearance to zero.
Seth Madore
Message 7 of 9
seth.madore
in reply to: MJP63
I've opened CAM-51580 to investigate this issue
Seth Madore
Message 8 of 9
MJP63
Any update on this issue (CAM-51580)?
Message 9 of 9
seth.madore
in reply to: MJP63
No update, sorry. In all transparency, it could be a bit of time before this is resolved, sad to say.
Seth Madore
