Adding Spindle P Codes
danieldonaworth
danieldonaworth
I'm trying to modify the post processor for the Samsung mill turn post for a Smart NL2000BSY Lathe.  On the Smart I need it to out put P1 for main spindle P2 for sub and P3 for live tooling when doing a M3 or M4.  Is there any good way to easily add this?
seth.madore
Well, you have two options:
1) Take a look at the syntax in the Doosan Mill/Turn post, copy over the required sections of code
2) Start with the Doosan Lynx post and modify that one to suit your needs. You would want to select "Lynx with Y" if your machine has a Y axis.
Seth Madore
