Fusion Manufacture
Adding a chamfer to steel part, using ballnose cutter...
4 REPLIES 4
jared_seymor
123 Views, 4 Replies
Full disclosure, I'm new to Fusion360 but believe I have successfully fumbled my way through a lot of it.
I am trying to add a chamfer to this steel part, using a ballnose end mill but am not sure how to do it.  Can anyone help guide me to making a chamfer and using a ballnose, using multiple passes?
Edit:
I can do it via 2D chamfer, but only using a chamfer bit in 1 pass.
Also, the model in Fusion360 does not have the chamfer built in and I'm using the model as stock, if that matters.
4 REPLIES 4
DarthBane55
in reply to: jared_seymor
Hi, many ways to do it.  Parallel, Flow, Flow Preview would be the easiest and probable best ones to try.
jared_seymor
in reply to: DarthBane55
Can I do Flow (never used it before) if the chamfer isn't already built in to the model?
seth.madore
No, you need to have the chamfer modeled.
If the issue with a Chamfer tool and one pass is that it's too much of a cut, you could duplicate the toolpath and play with different values to give you a quasi form of "multiple depths"
Seth Madore
jared_seymor
Thanks guys, I modeled the chamfer in and was able to get it to work using Parallel.  did exactly what I wanted.  Thanks again.
