I have these bits that I ordered from Inventables. They are described as V Carving bits. I would like to use one of them to make a chamfer on a piece of MDF. One is 90 degree and the other is a 60 degree one. I would like to add them to my tool library but am lost as to what to put in for the parameters. Do I choose it as a chamfer bit or counter sink bit or something else. I assume the taper angle is not the same as the angles stated below since it is asking for a number less than 90 degrees and one of the bits are described as a 90 degree V bit. What would I enter for tip diameter? Here is all the info I have from the inventables website:
desktopmakes.com
