Fusion Manufacture
Add wait cycle with M8
10 REPLIES 10
Message 1 of 11
rogerUKU85
216 Views, 10 Replies
Is there a way to make the post processor add a wait cycle after doing an M8
We have an old machine and the coolant takes a while to start flowing through the nozzles, we have been doing it by hand but would save alot of time on the machine if we could automate it, we are using the generic heidenhain post processor for 530
10 REPLIES 10
Message 2 of 11
Hi, can you share the used post processor and add the standby code manually.
Message 3 of 11
rogerUKU85
in reply to: rogerUKU85
Im sending our post But ill post an example aswell
10 TOOL CALL 14 Z S3762
11 L M140 MB MAX
12 M126
13 M3
14 L B+90 C+270 R0 FMAX
15 L X-124.225 Y-19.1 R0 FMAX
16 L Z+58.734 R0 FMAX
17 M8
18 CYCL DEF 9.0 DWELL TIME
19 CYCL DEF 9.1 DWELL 3
20 CYCL DEF 32.0 TOLERANCE
21 CYCL DEF 32.1
22 CYCL DEF 200 DRILLING ~
  Q200=+5 ;SET-UP CLEARANCE ~
  Q201=-0.65 ;DEPTH ~
  Q206=376 ;FEED RATE FOR PLUNGING ~
  Q202=+0.65 ;INFEED DEPTH ~
  Q210=0 ;DWELL AT TOP ~
  Q203=+39.484 ;SURFACE COORDINATE ~
  Q204=+9.25 ;2ND SET-UP CLEARANCE ~
  Q211=0 ;DWELL AT BOTTOM
23 L FMAX M99
24 L Y+8.9 FMAX M99
25 L X-118.475 Y+168.524 FMAX M99
26 L Z+58.734 FMAX
27 M9
28 M5
29 L M140 MB MAX
Its line 18&19 we would want added directly after the M8
Message 4 of 11
Is it ok for you to be here
0 BEGIN PGM 1001 MM
1 ;Manus parcas�
2 BLK FORM 0.1 Z X-80 Y-55 Z-40
3 BLK FORM 0.2 X+80 Y+55 Z+0
4 ;-------------------------------------
5 ;Tools
6 ;  #1 D=50 - ZMIN=-1.84 - ZMAX=+16 - face mill
7 ;-------------------------------------
8 ;
9 PLANE RESET STAY
10 * - Face2
11 M5
12 TOOL CALL 1 Z S891
13 L M140 MB MAX
14 M3
15 LBL 1
16 CYCL DEF 247 DATUM SETTING ~
  Q339=1 ; DATUM NUMBER
17 LBL 0
18 PLANE RESET TURN FMAX
19 L X+112.5 Y-42.758 R0 FMAX
20 L Z+16 R0 FMAX
21 M8
22 CYCL DEF 32.0 TOLERANCE
23 CYCL DEF 32.1
24 L Z+3.16 FMAX
25 CYCL DEF 9.0 DWELL TIME--------- add this
26 CYCL DEF 9.1 DWELL 3 -------------add this
27 CC X+107.5 Z+3.16
28 CP IPA+90 DR+ F357
29 L X+105.01 Z-1.84
Message 5 of 11
rogerUKU85
yes that would be fine just needs to be before the tool comes into contact with material
Message 6 of 11
If you edit as in the image, you will get the output of the post I sent. I achieved it by adding the onDwell code to the first Z move. onDwell(second)
Message 7 of 11
rogerUKU85
hmm kinda works but i would want it to only post a dwell if theres a M8 if thats possible somehow
Message 8 of 11
For after M8, edit as shown in the picture. If your problem is solved, please accept the solution 🙂
Message 9 of 11
rogerUKU85
still does it when theres no M8
Message 10 of 11
rogerUKU85
fixed it by doing
Message 11 of 11
You should check for other coolant options. I think I made a way for you
