Fusion Manufacture
Add "Points" and "Diameter Override" to Bore cycle?
4 REPLIES 4
programming2C78B
98 Views, 4 Replies
this would be nice to have. I can select a point to drill, but then also need to model a surface cylinder to bore it out? How about we just add these two features to the Bore stategy, think akin to how Thread Mill works!
I am currently roughing out the bulk of a pocket with a U drill, then REST adapting. It would be safer in this Ti to be able to bore cycle the little islands of material instead of the program thinking it's 100% gone and just speeding through it all.
Please click "Accept Solution" if what I wrote solved your issue!
4 REPLIES 4
You can use the bore milling cycle under the drill menu to mill bores with selected points
The toolpath fails to generate for me. Are you using a single sketch point?
edit: you have to still select the drawn circle, not the center point.
Are you using "Selected Points"?
Seth Madore
I was initially yes, but if I do Selected Diameters (and select the sketched circle) it will work! Funny how the toolpath is still a plunge, but simulates the actual helix in.
Can these overrides/features be added to the Bore cycle? In my mind it should be as simple as a copy paste 😉
My guess is that the software is simply creating a canned cycle in the background and uses the center point as initial coords.
