Fusion Manufacture
Adaptive Clearing
1 REPLY 1
nevHXRWF
61 Views, 1 Reply
Adaptive Clearing
Hi Folks,
Sometimes when needing to clear material with an adaptive tool path it's a compromise between selecting a big enough tool to take larger steps overs and getting into all the smaller corner radius of pockets.
Adding sketches to clear certain areas is not optimal, annoying and time consuming.
Would it be possible to select 2 (or more) tools, so the smaller tool is used where the larger can't get to due to its diameter constraints?
Or is there a way to do this with already?
Neville
1 REPLY 1
a.laasW8M6T
in reply to: nevHXRWF
Just use rest machining set to "From previous operations"
This will only machine areas that the previous tool cant get to
