Fusion Manufacture
Adaptive clearing - setting "small stock to leave" makes holder collide with stock
1 REPLY 1
r.moss
86 Views, 1 Reply
I am profiling the end of a tube using a 12mm ball-nose cutter and adaptive clearing.   This is to make parts that match for welding, so a perfect finish is not essential.
The stock has the central hole machined already, so only the highlighted face needs to be milled.  I have selected this face in the adaptive setup.  The "include setup model" is disabled (but does not influence the problem, as far as I can see).
If I set "Stock to leave" at 0.01mm, or disable it, the toolpath makes the tool dive inside the end of the tube until the holder hits the top edge.  I cannot see why it wants to do this.
Setting 0.5 mm Stock to leave avoids the diving inside behaviour:
If I leave 0.5 mm stock I will need a finishing operation to bring it to size - seems unnecessary, given that the adaptive finish is so good (on a mild steel trial piece - final items will be stainless).
Is this a bug?
The file is here: https://a360.co/3hueqtC
Roger
1 REPLY 1
seth.madore
in reply to: r.moss
With Stock to Leave set to .01, it's going to get to deeper areas than the .05 value.
A better method would be to define boundaries:
 This has the benefit of better constraint and reduced cycle times as well
Seth Madore
