a problem with the drill tools
none of the tools appear in the drill option in the cam work space even though all of them appear in the tool library
Marco.Takx
Hi @Anonymous,
Can you be more specific of what is not working?
When you start a Drill Operation select a Drill from the tool library and select a hole in the model. What is not working.
Can you share your model?
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
the problem is when i open the drilling operation and click on select tool the library appears empty
even though when i click on the tool library preview tab it contains all the toolsthe tool library previewthe tool library previewthe tool library when i click on select tool in the drilling operationthe tool library when i click on select tool in the drilling operation
jeff.pek
In the 2nd picture, you only have the Document selected on the left-hand side. So, it only shows you tools that have already been used in that document. In the first picture, "All" is selected, and so you see all of the tools from all (checked) libraries.
Jeff
