Fusion Manufacture
5-axis simultaneous cycle pre-position Mazak with G68.2
2 REPLIES 2
robseago
226 Views, 2 Replies
Hi All
Is anyone using Fusion on a Mazak to machine 5-axis simultaneous cycles? We have a Vari-axis C600 and are struggling to get the pre-positioning before running a simultaneous cycle.
From the machine home, it's currently moving in X/Y/Z to the cycle start point, which causes issues if you're machining with the B-axis tipped over, as if it's an extension tool, you'll likely smack into the trunnion. What we'd like it to do, is use G68.2 (3+2 positioning), to get the tool to a safe position near the job, then use G43.4 to start the simultaneous cycle.
Any help greatly appreciated!
2 REPLIES 2
BrandonTBFBF
in reply to: robseago
Can you attach your post here.
I've done this for our Okuma M460-5ax and I may be able to help.
v.tsybulnyk
I have the same problem with the same machine ,I would aslo like to now wat is the best solution
