Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
5 axis contour - tool orientation jitter and skipped passed
4 REPLIES 4
designingberlin
339 Views, 4 Replies
I'm currently experimenting with 5axis toolpath and this one seems to be trickier than expected: 4 concentric circles on a sphere.
This shown the default result with 0.01mm tolerance. The tool orientation is not what I'm after. Sure, the model gets triangulated and every facette has its own normal. So I increased the tolerance to 0.001mm.
Thats better, but still rather jittery for a nice cut. So 0.0001mm tolerance:
tool orientations look good now, but some issues arise:
1) new warning box shows up (Warning: One or more passes were completely skipped.) and only 2 circles are part of the toolpath now.
2) I dump-posted the file and found more than 500 linking moves
( 500+ calls of onMovement(MOVEMENT_LINK_TRANSITION /*transition*/) )
Something is not right here.
Is there a good way to get suitable tool orientations without increasing the triangulation tolerance that much? Some kind of averaging might already help (without being ideal).
Stefan
Labels (5)
4 REPLIES 4
Go into "Compare and Edit" (right click on the toolpath to get there) and search for "Surface Triangulation". Set it to "tolerance * 0.05"
Result:
Seth Madore
@seth.madorethanks. will do.
I didn't know about that additional triangulation tolerance.
This is going to increase calculation time quit a bit isn't it?
Stefan
It didn't seem to add too much to this piece
Seth Madore
That did the trick. Big Thanks !
Technology Administrators
