Fusion Manufacture
5 axis A axis posting issue
1 REPLY 1
TurboTroninc
78 Views, 1 Reply
Hello, I am having an issue with my post process & reading with my machine. When posting via fusion, my code will have
"G0 A-90. C135." This is fine, however the A-90. will throw a code on my machine (HAAS VF-2 SS w/ TRT100). Upon removal of the "." making it "A-90" everything will be fine. (The "C135." will throw a code when the "." is removed however). I am using post from Haas/ Fusion (unsure if it came with machine but it is Haas Next Gen Control). What should i edit in the post to remove the ". " for only the A axis? or is there something in machine settings?
Much appreciated
1 REPLY 1
AdamKunzo
in reply to: TurboTroninc
Search "var abcFormat". Copy this line and change "abcFormat" to "aFormat" and set forceDecimal to False
Then search "aOutput" and  change abcFormat to "aFormat"
You can take a look at attached PP.
If my post answer your question, please use Accept as Solution.
