4th axis milling and trace function
- Mute
- Permalink
- Report
I am trying to cut an access segment out of a conical object, and I am having to use both the contour and trace functions to get the cuts that I need. We tried to do a test run and found that after performing the contour around the cylindrical base it does not reset the A axis before performing the trace. Is there anyway to set Fusion to correct or reset the A axis before it starts the trace function?
Fusion
