4th Axis Indexer and Shopbot Post-Processor
I'm struggling to get Fusion's CAM+Postprocessor to produce a file that will work with the 4th axis indexer on our MakerLabs' Shopbot PRS. Please bear with me as I lay out the details below.
I've stripped things back to something extremely simple. In the attached FBD, I've modelled up a 4" x 2" x 2" block oriented as shown below.
For CAM, all I'm going to do is use a 1/4" end mill to touch the existing border of each of the long faces. I do a 2D contour on one face at the model height and then pattern it with 4 90-degree rotations. That is, I'm not unwrapping anything, just changing the tool orientation to bring up a new face. With this geometry and toolpaths, we should only see movements with x coordinates of 0, 4 and y,z coordinates of -1,+1.
With the stock OpenSBP post, and with properties set to have rotations about x axis (default) and 4th axis turned on as shown here,
I get the following part file:
' TraceBoxTest SA CN, 90 IF %(25)=1 THEN GOTO UNIT_ERROR &PWMaterial = 2 &PWZorigin = Part Surface ' 2D Contour1 (2) JZ, 3 JH J5, , , , , 0 C7 &Tool = 2 TR, 8000 C6 PAUSE 2 J2, 0, 1 J3, 0, 1, 2 J3, 0, 1, 1.5 MS, 0.5556, 0.5556 M3, 0, 1, 1 MS, 1.6667, 1.6667 M3, 4, 1, 1 M3, 4, -1, 1 M3, 0, -1, 1 M3, 0, 1, 1 M3, 0, 1, 1.2 J3, 0, 1, 2 ' 2D Contour1 (2) JZ, 3 JH J5, , , , , 270 J2, 0, 1 J3, 0, 1, 2 J3, 0, 1, 1.5 MS, 0.5556, 0.5556 M3, 0, 1, 1 MS, 1.6667, 1.6667 M3, 4, 1, 1 M3, 4, -1, 1 M3, 0, -1, 1 M3, 0, 1, 1 M3, 0, 1, 1.2 J3, 0, 1, 2 ' 2D Contour1 (2) JZ, 3 JH J5, , , , , 180 J2, 0, 1 J3, 0, 1, 2 J3, 0, 1, 1.5 MS, 0.5556, 0.5556 M3, 0, 1, 1 MS, 1.6667, 1.6667 M3, 4, 1, 1 M3, 4, -1, 1 M3, 0, -1, 1 M3, 0, 1, 1 M3, 0, 1, 1.2 J3, 0, 1, 2 ' 2D Contour1 (2) JZ, 3 JH J5, , , , , 90 J2, 0, 1 J3, 0, 1, 2 J3, 0, 1, 1.5 MS, 0.5556, 0.5556 M3, 0, 1, 1 MS, 1.6667, 1.6667 M3, 4, 1, 1 M3, 4, -1, 1 M3, 0, -1, 1 M3, 0, 1, 1 M3, 0, 1, 1.2 J3, 0, 1, 2 C7 JZ, 3 JH J5, , , , , 0 END UNIT_ERROR: CN, 91 END
At first glance this looks like a reasonable post. Shopbot uses the "B" axis for the indexer so the "J5, , , , , angle" commands would seem to make sense. We also see that the M3 move commands trace the rectangular border as expected (with a terminating retract in z). However, when I load this file into Shopbot's control software, the visual preview of the tool paths don't look correct:
I raised this issue directly with Shopbot and they pointed my at the following PDF, http://www.shopbottools.com/ShopBotDocs/files/WrappingRotaryIndexer.pdf. The title though, "Setting Up a Wrapping File for the ShopBot Rotary Indexer", makes me wonder if they really understood the issue. I'm not trying to unwrap a cylindrical model, rather just add an extra degree of (rotational) freedom and then have full axis to x,y,z movements. What we see above is that the "cutting" toolpaths don't change in Y. After reading the above PDF, I'm starting to wonder if this is a hardware limitation. Here's an excerpt from Page 3:
Thoughts?
Cheers,
Darran
P.S. In a vain attempt to fix this issue, I tried upgrading to the Version 42035 OpenSBP post-processor. Unfortunately that won't even work on the attached FDB, generating the following output:
Information: Configuration: ShopBot OpenSBP (Experimental) Information: Vendor: ShopBot Tools Information: Posting intermediate data to '/Users/darran/Fusion 360 CAM/nc/TraceBoxTestExperimental' Error: Failed to post process. See below for details. ... Start time: Sun Jul 1 01:40:47 2018 Post processor engine: 4.2.1 41970 Configuration path: /Users/darran/Library/Application Support/Autodesk/Autodesk Fusion 360/CEWDMG9Z9PGW/W.login/M/D20180507130870481/CAMPosts/18F30-Shopbot.cps Include paths: /Users/darran/Library/Application Support/Autodesk/Autodesk Fusion 360/CEWDMG9Z9PGW/W.login/M/D20180507130870481/CAMPosts Configuration modification date: Sun Jul 1 01:27:12 2018 Output path: /Users/darran/Fusion 360 CAM/nc/TraceBoxTestExperimental Checksum of intermediate NC data: 2c1da62b181704bf931fb898ee16d3d6 Checksum of configuration: 21b4718ad3471690e3486296be02232b Vendor url: http://www.shopbottools.com Legal: Copyright (C) 2012-2018 by Autodesk, Inc. Generated by: Fusion 360 CAM 2.0.4279 ... Error: Failed to invoke function 'onSection'. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Error: Failed to invoke 'onSection' in the post configuration. Error: Failed to execute configuration. Stop time: Sun Jul 1 01:40:47 2018 Post processing failed.
Note that I edited the title to include "(Experimental)" just so I didn't confuse it with the stock post.
