Fusion Manufacture
4 AXIS G93 PROBLEM
4 REPLIES 4
emre_sahin9PU3F
133 Views, 4 Replies
4 AXIS G93 PROBLEM
Hello
When doing 4 Axis programming, I give F2000 for all progress. When I receive a post, the F values ​​are constantly changing. I want all my F values ​​to be constant. Variable F values ​​cause loss of time on the machine. 16 minutes of processing time in the program takes 2 hours on the machine. It slows down in the viewfinder up to F5.1. I don't want it to work in reverse time feeding mode.
4 REPLIES 4
AdamKunzo
in reply to: emre_sahin9PU3F
Hi Emre,
Seems like your machine does not read the inverse feed rate mode correctly.
If you'd like to get a help, I offer post processor modification as a service and I can remove the inverse feed and use standard G1 F2000 instead.
Send me a message for a help.
Try the attached.
I will warn you though, your programmed feedrate will not be accurate.
Thank you for the help. I will let you know the result after trying it on the machine.
emre_sahin9PU3F
in reply to: AdamKunzo
 Thank you for the help. I will get back to you on the progress after seeing it on the machine.
