4-Axis floor and corner finishing
nletwinWVXPP
nletwinWVXPP
I am trying to surface machine a U shaped part using an Okuma M560 with a rotary axis. I have attached a generic example part with some of my attempts.
I have two related problems.
At the end of the U there is a concave fillet in the corner that I am trying to finish using a continuous 4-axis tool path to prevent holder/wall collision. I would like to be able to do it either with a single pass from the correct sized ball-nose tool, or using multiple step downs with a smaller tool. I have tried a 4ax multi-axis contour toolpath with collision avoidance, however the toolpath does not run up the vertical walls. I was able to get a blend toolpath to do the stepdowns that I wanted, however it is extremely slow to calculate and seems to choke when more complex geometry is present (lots of weird segments and retracts)
CornerCornerBlendBlend
I am also trying to use something like steep/shallow to finish the rest of the surfaces, however the toolpath does not want to go up the vertical walls. I can kind of make it do what I want by splitting the toolpath into a left and right hand version with a little bit of tilt set in the tool orientation tab, however I would prefer to not have the seem in the middle if possible
a.laasW8M6T
Steep and shallow will machine all the way up the sides if you turn off contact point boundary
Its not really the optimal toolpath here
When I get a chance later ill have a look and see If I can come up with a better solution
Andrew Laas
Senior Machinist, Scott Automation
a.laasW8M6T
Here's a   few options to look at
(view in My Videos)
Andrew Laas
nletwinWVXPP
Absolutely fantastic. You answered all of my questions and then some. I can't thank you enough.
