Fusion Manufacture
3MF Scene Export not available after May 30 update
5 REPLIES 5
AWR5015
242 Views, 5 Replies
Hi,  I noticed after the latest Fusion 360 update (posted May 30th), the 3MF Scene Export is no longer available on any of my models.   Previously I was able to select export my setup data from the Actions pull-down menu.
According to the update, there should be a new icon within the Additive Manufacturing  - Actions menu tab.  I did read on the follow up link that an FFF enabled Printer should be selected within the Setup (which I have double checked), but, the option still is not appearing for me. (https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-AM-HOW-TO-EXPORT-TO-3MF)
Is anyone else seeing this issue?
5 REPLIES 5
ianchantrell
in reply to: AWR5015
  • I have the same problem. The 3MF scene export choice in Manufacturing/Actions no longer exists. This is irritating as I used it a lot. It is still possible to export the entire file in file/export and choose the 3MF export option but this is not something I would want to do. Look forward to a solution, preferably by reinstating the 3MF option. Any clue as to why it was removed?
AWR5015
in reply to: ianchantrell
Yeah, the 3MF Scene Export was very useful.  I'm really not sure why the feature was removed, especially since the 2.0.16265 update notes clearly state that it should be there as a standalone button.  I ended up starting a thread in the Support Forum since it seemed like a bug with this version release.  Hopefully it gains some traction to fix the issue soon...
And I agree that the File > Export as "3MF" isn't ideal and definitely is not the same as the "3MF Scene Export".  For me, that option doesn't capture all the build plate models (including support geometry) with the manufacturing model, which I was relying on for additional post-processing.
I've tried toggling between different FFF Printer setups and other types (as the help page suggests), but nothing enables the export like it states.
serge.quiblier
Hi All,
It seems strange.
I am using the latest update of Fusion.
I have a model, and an FFF setup.
And the option is there :
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
serge.quiblier
This menu option had moved into the additive extension.
But a possible work around can be used, from the Design workspace, in the right click menu over a body
Then, select the output format
I hope it will be usefull to you.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
cam.autodesk.com
AWR5015
Thanks for looking into the issue @serge.quiblier.
Had a feeling the 3MF Scene Export feature got moved behind the  Additive Extensions.  The notes from the help page and update notes for v2.0.16265 made it seem like it was still available in the basic Fusion 360.
It's a bit unfortunate, since without the scene export directly available, the Additive Manufacturing module doesn't have any option to export the entire bed model with support geometry anymore.  For my use-case (running older/legacy printers), it may be more practical to move away from Fusion's Additive Manufacturing and going with a different printer platform all together, since I'd only be using the extension just for that 1 feature...
I've also tried the Save as Mesh -> 3MF Export method that was mentioned as a workaround,  however, it only looks at the design body/models and ignores any manufacturing geometry. So from what I was seeing, it's no different than just saving the design as an STL, which isn't as useful for my application.
