Fusion Manufacture
3D Sketch Boundary for machining
4 REPLIES 4
b.tarek
119 Views, 4 Replies
Hi, is there a way that I can use a 3D sketch as my boundary in Fusion and have the toolpath be confined to it in all axes (X,Y,Z) like using the boundaries in PowerMill as shown below.
4 REPLIES 4
seth.madore
in reply to: b.tarek
Using any sketch as a boundary only gives you a flat (2D) boundary to constrain the toolpath. What exactly are you trying to limit of accomplish, as I've not seen this asked before 🤔
Seth Madore
b.tarek
I am trying to limit the toolpath to the one side of the part as I'll flip it and work on the other side separately so I don't want to machine the bottom side and I don't want it dipping into certain spots to try to machine it.
It's also not obvious in the attached photo but the part is actually a .stl file so selecting faces to avoid will take a very long time as it has a lot of faces and reducing the number of faces using the mesh tools messed up the dimensions of the part and converting it to a solid also didn't work.
You'll find the stl file attached
seth.madore
In the file you shared, it's not clear what or where you're trying to avoid. My first instinct is to suggest that Fusion is not the best solution for a part such as this, only because it's an .STL file. While Fusion is capable of creating code on .stl files, there's certainly a lack of flexibility and control over the results.
Seth Madore
b.tarek
in reply to: seth.madore
Thank you so much, I have noticed that Fusion does work slightly better with solids so I'll just try to work around that using the 2D boundary.
