Fusion Manufacture
3D Scallop getting "Internal CAM error"
4 REPLIES 4
lens42
157 Views, 4 Replies
I'm trying to do a scallop cleanup op of a domed surface and I can't get a toolpath to generate. The roughing spiral CAM for the dome generates with no problem. I've looked at forums and YT with no luck. I suspect I am doing something wrong as this is the first 3D curved part I've attempted. What might be related is that I can't even seem to see in the geometry tab where I select the surface I want to cut, though in the videos I've watched a surface never seems to be selected, but a toolpath is still generated (in the tutorial videos, not for me) File attached. Thanks in advance.
4 REPLIES 4
seth.madore
in reply to: lens42
Hmm, it does appear that Scallop does not like that surface one bit.
However, you may be able to find a suitable solution in Morph:
I've attached the file and will get the Scallop issue logged as a bug
Seth Madore
seth.madore
in reply to: lens42
I think I may have found the "Why". It might have to do with your tool size. If I drop the 4th and 5th place decimal of the tool (.15625) down to .156", we get a toolpath. If I use a .187 or .375 Ball endmill, I get a toolpath.
If I go back to a math function of "5/32", it returns .15625 and fails. If I manually type in .1562, it succeeds:
Seth Madore
seth.madore
in reply to: lens42
And it looks like this is covered in CAM-33813 already. It looks like the kernel is having some rounding issues between cutter diameter and tool radius value
Seth Madore
lens42
in reply to: lens42
Thanks so much.
