Fusion Manufacture
3d printing simple two part fixture
8 REPLIES 8
Message 1 of 9
steveYSB47
198 Views, 8 Replies
I'm printing a simple two part fixture. Basically a rectangular base with 4 pegs.
The base is one design and then the peg is a second design. The base then uses 6 references of the "peg" design
However, when it 3d prints, it looks right - but the pegs are actually separate parts that are printed inside recessed holes within the base. How can I "join" or fuse it all together so I can still use the independent "peg" design but have one "solid" STL file when its output for 3d printing?
8 REPLIES 8
Message 2 of 9
seth.madore
in reply to: steveYSB47
Would you be willing/able to share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d/f3z file in your reply
Seth Madore
Message 3 of 9
You'll want to use the Combine tool, export as stl, then (potentially) undo or suppress the join command.
Please click "Accept Solution" if what I wrote solved your issue!
Message 4 of 9
i tried that a few times, but that doesn't appear to work. not sure what i am doing wrong
Message 5 of 9
steveYSB47
in reply to: seth.madore
See attached - thanks for looking. Not sure what I am doing wrong here.
I'd like to output one solid model of the base platform and the four pegs. Must be some option in either the STL generation? I can't get the "combine" feature to do it either
Message 6 of 9
Warmingup1953
It appears only one peg is not combinedScreen Shot 2023-02-26 at 12.07.35 am.pngScreen Shot 2023-02-26 at 12.10.48 am.png
Message 7 of 9
I needed to add some meat as a simple combine did not work ( i didnt investigate)Screen Shot 2023-02-26 at 12.23.41 am.png
Message 8 of 9
steveYSB47
in reply to: Warmingup1953
how did you get this view? i cannot see that on my side?
Message 9 of 9
seth.madore
That's a "Section Analysis"
Seth Madore
