Fusion Manufacture
3d Pocket will not machine full pocket depth - flat area detection
3 REPLIES 3
toolcontrolreliability
115 Views, 3 Replies
Hi All,
I'm struggling to create a suitable machining operation for my tool shadow board. 3d pocket clearing with flat area detection is exactly what I need, but the step downs are too small, and the machining time is way too long.
However, when I deselect flat area detection, the tool path now doesn't machine to the bottom of the pocket! Why? I'm using roughing step down of 12mm. Can anyone shed some light?
@HughesTooling @seth.madore
3 REPLIES 3
Your attached DXF will not open in Fusion 360 or AutoCAD 2024.  Please attach your native Fusion 360 model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
thanks John, hopefully this one is it
I'd actually suggest using the Flat toolpath, it offers greater control over step downs and the like:
Seth Madore
