Fusion Manufacture
3D Pocket - Tool path not as expected
5 REPLIES 5
MetalRipper_
197 Views, 5 Replies
Hi folks
For the following part - in second setup, I'm trying to rough out rest stock using 3D Pocket tool-path with "plunge outside the stock" option. But tool doesn't go to the selected bottom instead it stops at -6mm. If i use "Helix" or "Zig-zag" tool reaches till selected bottom but when I use "Plunge outside stock" option, it don't travel as I expected. Kindly assist in resolving this problem.
Thanks.
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
5 REPLIES 5
EDIT. After running the simulation this is not a very good toolpath as it is not using the stock from the previous setup and machining lots of air. Not sure if this is a limitation for Fusion.
If I set rest to from previous setup I think it works?
Mark Hughes
Owner, Hughes Tooling
Also in your first pocket in setup1, is there a reason you don't have the boundary set to none so it machines from the outside rather than pocketing? I've attached your file. Double check everything because I did experiment a bit before coming up with this.
Mark Hughes
Seems like you can workaround this if you just duplicate the pocket op in the second setup and just generate. So just use 2 pocket ops with the same settings and rest from previous operations. I've attached the file.
Mark Hughes
Hi @HughesTooling
Thank you for your reply.
This method works but the rest machining stock is kept from setup stock hence some non-cutting toolpaths are present. I've played with the settings and found a way to avoid this. There seems to be some complications with stock contours and rest machining materials.
Thanks for the second suggestion, I failed to notice it earlier and changing it to "Plunge outside the stock" drastically reduced the run time by 50%.
Gokul Kannan
Hi sir
You might see the same thing I've repeated again. I was keeping your old reply open and was parallel working on Fusion and typing the reply. By mere coincidence, we've reached the same conclusion.
And thank you again for taking time to reconsider and solving my problem.
Gokul Kannan
