Fusion Manufacture
3d Pocket Problems
2 REPLIES 2
jscott6SWZG
135 Views, 2 Replies
3d Pocket Problems
I can select the face I want to machine down to but tool path ends at top of intended cut not the bottom
See attached
set up binding top
op Pocket 12
2 REPLIES 2
a.laasW8M6T
in reply to: jscott6SWZG
Hi
When you select a face the height always goes to the highest point on that face:
see the dark blue line:
Really all you can to here is put a  negative offset to get the bottom height to where you want:
jscott6SWZG
Thanks that helps.  Think that will beat the 2d contour. Path that i couldn’t get to extend out to complete the cut
